Loading effect problem in a circuit
rocky010589
Newbie level 3
Newbie level 3
Hello everyone,
I am doing a project in which, I am using a power supply of 12V. when I have not given any load, then it give 52V at o/p. But when give the load then it reduces to 30V, 350mA. but I want at o/p 30V, 720mA.
What I have to do????
Plz give me suggestion...
Thank you...
I think your load resistance should be changed(deccreased) in order to draw more current from the supply.
Hello everyone,
Thank you...
Hi all,
What current will load use from power supply depends from resistance in circuit and from resistance of load. Of course, its obvious that psu must have enough current to supply load or we will have smoke. :smile: If load have smaller resistance current will be higher.
When transformer is made, all depends from construction calculations. Trafo can be constructed to have nominal voltage at full load (max power) or can have OCV voltage (Open Contact Voltage - without load). Your adapter is probably very small, and you have voltage falldown.
You cant put more current in load, this depends from load resistance and resistance in circuit.
Hello everyone,
Thank you...
If you use a regulated power supply (RPS) you will not face this problem.
The RPS should be able to supply at-least 720 mA of current at 30 V.
You can easily make your own, a stepdown transformer connected to a rectifier with filter which is connected to voltage regulator could make this.
It is easily available in market, you can buy one.
