Load pull simulation in ADS need help
TerryADS
Full Member level 2
USA
Hi friends,
The first time simulate load pull,a question about the DC block and DC feed components as attached photo,whether i need modify the cap. and RF choke values if i use another device and different frequencics simulated.Or i insert the device into the example directly(why?)?
Thanks,
BigBoss
Advanced Member level 5
Turkiye
No..
The values are sufficiently high for RF frequencies ( if they are higher than 100MHz )
    TerryADS
jayce3390
Full Member level 6
Don't modify these values, it's acting as a bias tee. You can measure different devices in different frequency band with the same bias tee.
The simulation result is not depending on these values.
    TerryADS
penghan
Member level 4
Shanghai
These caps and inductors are large enough. They hardly have any effect on smith chart for high frequency application.
