graphene
Full Member level 2
- Joined
- Mar 22, 2012
- Messages
- 129
- Helped
- 4
- Reputation
- 8
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Germany
- Activity points
- 2,181
I want to set a default output pin capacitance that my RTL compiler would follow.
Instead of manually definign the load thru sdc files is it ok if i simply change the set_output_max_capaicantce to my desired load ??
such a deifnition is done in the library file... should the characterization be performed after such a load definition. ?? or delaring such load is as simple as a dummy argument assigned to the RTL compiler...
