Jester
Full Member level 6
For a consumer type product that will use a Lithium Ion Battery (3.7V about 150-200mAh), what safety standards apply that I should be aware of?
In practical terms, if I use an appropriate Li-Ion charging IC (for example L6924U) and follow the specification sheet am I likely to have a reliable and safe design?
A quick search at Digi-Key only shows batteries with limited capacity (100mAh), can anyone suggest a source for a higher capacity battery (150-300mAh)?
Some batteries come with a built in NTC thermistor, how important is this?
Thanks in advance for sharing your wisdom.
