linked list help needed
john2020
Full Member level 5
Full Member level 5
I need to allocate a block of 256 bytes and insert into the first node linked list and free block from linked list.
I use c language. I am not aware of container classes. here is what i wrote so far...can u help me?
//insert a node into a linked list
struct node *pNew;
pNew = (struct node *) malloc(sizeof(struct node));
pNew -> data = item;
if (pPre == NULL){
//add before first logical node or to an empty list
pNew -> next = pHead;
pHead = pNew;
else {
//add in the middle or at the end
pNew -> next = pPre -> next;
pPre -> next = pNew;
please review this code and tell me if approach is correct? I am still not clear as to how to create new block of same size and add to exisitng list.also do i need to add node at the tail of the block?
#include <stdio.h> /* for printf */
#include <stdlib.h> /* for malloc */
struct node
int data;
struct node *next; /* pointer to next element in list */
struct node *list_add(struct node **p, int i)
struct node *n = malloc(sizeof(struct node));
if (n == NULL)
return NULL;
n->next = *p; /* the previous element (*p) now becomes the "next" element */
*p = n; /* add new empty element to the front (head) of the list */
n->data = i;
return *p;
void list_remove(struct node **p) /* remove head */
if (*p != NULL)
struct node *n = *p;
*p = (*p)->next;
free(n);
int main(void)
struct node *n = NULL;
list_add(&n, 0); /* list: 0 */
list_add(&n, 1); /* list: 1 0 */
return 0;
