rezadevelop
Newbie level 3
i have problem with characterization of complex cell.
my cell is complex & i can't use one ff or latch!
my cell.otp:
my ncx: Liberty NCX version C-2009.06-SP1
i think i can't use "ncx_multiple_descriptor".
I'm sure I'm doing something wrong, but don't know exactly where it is.
Thanks in advance
my cell.otp:
pin D {
direction : input ;
ncx_hold_rising_rise_constrained_pin_transition_index : 0 ;
ncx_hold_rising_fall_constrained_pin_transition_index : 0 ;
ncx_hold_rising_rise_related_pin_transition_index : 0 ;
ncx_hold_rising_fall_related_pin_transition_index : 0 ;
ncx_setup_rising_rise_constrained_pin_transition_index : 0 ;
ncx_setup_rising_fall_constrained_pin_transition_index : 0 ;
ncx_setup_rising_rise_related_pin_transition_index : 0 ;
ncx_setup_rising_fall_related_pin_transition_index : 0 ;
pin L2 {
direction : input ;
pin CKM {
direction : input ;
pin RET {
direction : input ;
pin CKLC {
direction : input ;
pin CKL2 {
direction : input ;
pin Sn {
direction : output ;
internal_node : IQ;
ncx_internal_power_rise_input_transition_time_index : 1 ;
ncx_internal_power_fall_input_transition_time_index : 1 ;
ncx_internal_power_rise_total_output_net_capacitance_index : 0 ;
ncx_internal_power_fall_total_output_net_capacitance_index : 0 ;
ncx_rising_edge_rise_input_net_transition_index : 1 ;
ncx_rising_edge_fall_input_net_transition_index : 1 ;
ncx_rising_edge_rise_total_output_net_capacitance_index : 0 ;
ncx_rising_edge_fall_total_output_net_capacitance_index : 0 ;
pin Sp {
internal_node : IQN;
pg_pin VDD {
voltage_name : VDD ;
pg_type : primary_power ;
pg_pin VSS {
voltage_name : VSS ;
pg_type : primary_ground ;
ncx_optimization {
statetable("D L2 CKM CKLC CKL2 RET","IQ IQN"){
table : "- - - - - 1 : - - : H L,\
L/H H/L - 1 - 0 : - - : L H,\
L/H L/H - 1 - 0 : - - : N N,\
r - 1 - - 0 : - - : L H,\
f - 1 - - 0 : - - : L H,\
L/H - 1 - - 0 : - - : N N,\
- L/H - - 0 0 : - - : N N,\
- r - - 0 0 : - - : L H,\
- f - - 0 0 : - - : L H ";
-----output result:
reading /home/.../TD_X1.opt...
Error: statetable(D L2 CKM CKLC CKL2 RET,IQ IQN) is not a valid group of cell. (NCXPS-22)
correct errors in /home/.../TD_X1.opt and rerun
cell types:
combinational : 1
pruning inactive cells...[0] done
done
Error: failed library database initialization (NCXDB-5)
Thanks in advance
