strahd_von_zarovich
Hi, i am trying to use TXS0102DCUR level shifter for I2C bus with FPGA. The problem is that when i am waiting for input from slave , i see weird voltage levels. While i am sending data and clock from FPGA nothing is wrong. However, after sending data request and if slave's response is low, it isn't low, it is about at 0.7V. Is it because FPGA can't sink current and input impedance is high-Z so i see 700mV. High pull-down resistor ll probably solve this problem what do you think ? :thinker:
FPGA's voltage levels is 1.8V and other side of the level shifter is 3.3V and nothing is wrong with the other side everything works perfectly. Level shifter has its own pull-up resistors for both sides with 10k.
