thanks, but we need to know if the 72 diodes on the strip are connected in series with each other, or in some series/parallel pattern.you asking about how diodes are connected i already show you on a given image from (+) goes one diode then i guess is resistor in serie then another diode ,all that in parallel with DC power
Well maybe ..you must know i don't build this strips .they are fabricated probably in China...If the above schematic is like your LED, then it is very inefficient.
Only about 8V across the LEDs and 16V wasted across the resistor.
Hi,Well maybe ..you must know i don't build this strips .they are fabricated probably in China...
...yes, i reckon the "72W" is the equivalent incandescant lamp power.........the actual real power consumed by your product i believe is much less.In my case tube is stated as 72W.
