T
treez
Hello,
Please could you help us because we believe an electronics design contractor company is trying to embezzle money out of us. We believe they deliberately designed a 140W LED power lamp for us with “problems” in it so that it would fail on thermal grounds. We believe that the electronics design contractor has pre-disposed the LED driver to fail on thermal grounds, knowing that since only they hold the PCB Layout files, we will have to go back and pay them to re-do the PCB to make it thermally acceptable.
There is also a microcontroller on the PCB and some signal circuitry, and he has layed this out so incredibly tightly that even though we have the schematic, we cannot replicate the PCB ourselves. We cannot make the PCB any bigger because all the enclosures have now been made.
The “problems” in the circuit relate to a lack of thermal spreading copper on the small LED driver PCB –this will likely lead to thermal failure…..the reason there is little thermal spreading copper on the PCB is because the designer added a large number of bogus “protection” components to the LED driver circuit, taking up lots of PCB space. These bogus components provide what the designer tells us is a “LED protection circuit”, which shuts off the LED load with a transistor switch whenever an overcurrent surge flows into the LEDs…..the designer tells us that if the LED connector ever becomes intermittent due to corrosion…..then the LED load will keep going open and then reconnecting…the designer tells us that when the LEDs go open, the output capacitors will over-charge (as the LED driver is a current source) and then when the connector re-makes, the overcharged output capacitors will deliver a surge of damaging current into the LEDs.
Thus the designer has added all of the components that you can see in the below schematic which he says, prevents damage to the LEDs and allows the microcontroller to detect that the connectors have become intermittent.
I believe this circuit is bogus….certainly running the simulation with and without the “led protection” components makes no difference….(the intermittent connector is simulated with a voltage controlled switch added to the simulation)
I admit that the comparator would trip on overcurrent, but does anyone seriously add such components to LED drivers?…I mean…how common is connector corrosion?…to the point where the contacts become intermittent?…I suspect bogus circuitry here.
I don't believe that the opamp that he uses as a "comparator" would trip quickly enough to stop the surge of current that he speaks about...and the simulation bears this out.
The designer also did not add much thermal spreading copper even where he could have done…and used no thermal vias to bottom spreading copper, even though he could have done this as the bottom layer is unpopulated. He also uses a 1206 high side sense resistor that dissipates 310mW.
We believe that he predisposed this circuit to fail, in the hope that since he holds the (Easy PC) PCB files (we do not have them), we will go back and offer to pay him to improve the PCB thermally.
What do you think? Do you think the “LED protection components” are bogus?
Why would the LED connectors be likely to corrode anyway?……even if they could, wouldn’t it be better to stop the corrosion by squirting silicone over them at assembly time.?
Schematic of LED driver with suspected “bogus” led protection components attached, as well as an LTspice file, showing the workings of the LED driver with the suspected “bogus” led protection circuitry.
