taofeng
Hi ,
I am desiging a LDO. And the Cout will be in a wide range from 100pF to 100nF. I am wondering how to do the compensation.
I would say it is better to make the dominant pole inside. However, the big issue comes when the load current is small and the Cout is large. So, I decide to use pole zero compensation. That is to say I internally generate an zero which will compensate the output pole in a wide current and Cout range.
The dependency of zero on the load current is relatively easy if you image just a current mirror. the problem now is to figure a circuit to track the change of the Cout. I completely run out of idea !
hope someone can help me out.
regards,
jeffrey
regards,
jeffrey
