[PIC] LCD data show garbage
Manjuhb
Newbie level 6
Recently I develop one project in which total 5 DC motor. The project contain 16x2 LCD display with PIC16F886. When use press key then motor will run. I observe that after some key operation LCD show garbage & it remain few minute. LCD runs in 4 bit mode. Garbage comes randomly some times for 3 iterations some times for 10 iterations and this design is done on the PCB board. Please let me know what could be the problem.
I have 0.1uF cap across the PIC IS also.
To drive motor I have used L298n H-bridge IC. I have used flywheeling diodes also across the motor connection.
most probably EMC problems.
caused by:
* wiring (maybe dividing power wires from signal wires, or the use of drilled pair wiring or shielded cables...helps)
* PCB layout (GND_plane, GND_plane, GND_plane!... EMC filters, low impedance signal lines...capacitors, a ceramics at least on each VCC pin, bulk capacitors, and on signal lines like RST)
* I/O EMC filters, I/O ESD protection
* system clock circuit..
Klaus
Feeding the microcontroller by the same power bus alread used by log devices is always a potential risk issue. In general it is a good choice to separate both.
We have all ready done 50 board. Please let me know how to solve this problem in existing boards. Thanks
May be you should show us that boards first?
Btw, schematics also will be helpfull.
Please find the attached schematics
  • PCB_Project.pdf
And pcb, please. Schematic looks good. Unused pins of LCD I recommend you to connect to ground.
