Layout technique explanation
Sadegh.j
Advanced Member level 3
explanation layout
Hi all
I am drawing my first HF layout ever in 0.13um IBM CMOS and I was wondering if there are any references to read to learn the basic layout techniques.
Thanks a lot
JoannesPaulus
USA
layout of an explanation
The Art of Analog Layout, Alan Hastings.
oermens
Advanced Member level 2
canada
ibm 0.13um layout
ibm 0.13um has layout pcells.. use virtuoso xl to convert your schematic instances to layout instances
Sadegh.j
hf layout
JoannesPaulus: Yeah, it is a famous book , may be a bit too much info.
oermens: Yeah, I have done that already, I am just looking for a short list of dos and don'ts, may be a tutorial of how to draw layout in cadence.
Thanks
JoannesPaulus
USA
explanation technique
If you have never done layout before, you should learn the basic techniques of matching, drawing busses and so on... you do not need to read the full book just the important chapters...
Sadegh.j
tagalog explanation ng center layout
Thanks
Do you may be have a reference that explanations how to draw layout in cadence?
erikl
Super Moderator
Staff member
Germany
high frequency layout technique.
Perhaps these lectures are helpful!?
oermens
canada
the layout of an explanation
you're doing high frequency layout... this is whats important:
1. differential
2. symmetry
3. symmetry
4. differential
if you can't draw a line down the center of your layout and perfectly split it in half, start over.
deepak242003
Full Member level 5
Banglore
lay out for explanation
At HF losses and parasitics are more prevalant.......
avoid using skinny traces..... long running parallel traces near to each other... try; to have as much symmetry as possible....
remaining i can say..... layout is an art of layout artist..cheers....
Sadegh.j
technique in doing a back layout
About the symmetry, I can understand that the two inputs should basically "see" the same transistors and all, but what if you have several blocks? Is it enough to make each block symmetrical? Or should the whole thing also be symmetrical?
