Latches in Altera designs?
alexz
Full Member level 5
UK
Latches in alera CPLDs
The following is a quote from the Altera's Recommended HDL
Coding Styles paragraph 6:
"Altera recommends that you design without the use of latches
whenever possible."
What does it mean?
jcchan
Member level 1
altera timing engine can not analyze it.
alexz
Full Member level 5
UK
Re: Latches in alera CPLDs
But I can still use it in the design can't I?
Hero
Full Member level 2
You can implement laches using asynchronous feedback paths in your cobinational logic. Probably you will have problems with time simulations.
Also you need to consider possible metastablilty problems. So don't use latch and inverted latch output at same time.
Setup and hold times are very routing dependant and upredictable.
With synchronuos solutions you can easy predict all timing parameters in your design.
alexz
Full Member level 5
UK
What are the disadvantages of doing the following latch?
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
entity latching is
port
signalIn : in std_logic_vector(15 downto 0);
signalOut : out std_logic_vector(15 downto 0);
inEn : in std_logic
end latching;
architecture latch_behaviour of latching is
begin
signalOut <= signalIn when inEn = '1' ;
end latch_behaviour ;
Iouri
Advanced Member level 2
Alexz,
It means you are not allowed to implimet something like RS flip-flop, and async design, all of your storage, needs to sync with input clock.
It is not only Altera, it is mostly all FPGA vendors...
Good luck!!!!
Hero
Full Member level 2
Most macro cell architectures only support flip-flops not latches. Without this support you need to implement latches with combinational logic using feeback paths. In this case your design is very timing and routing dependant and inefficient.
So if you really don't need latches use registers. If you use programmable logic array technology you can use leatches and registers without restrictions
