large font problem nikroc
engineer khan
Member level 3
This is the code which display large text on glcd but thats not clear to view the circuit diagram is attached please help me to solve this problem , my mission is to display large text on glcd
i'm using mikroc and pic18 mcu glcd
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
sbit GLCD_RS  at LATB0_bit;
sbit GLCD_RW  at LATD6_bit;
sbit GLCD_EN  at LATB2_bit;
sbit GLCD_RST at LATD5_bit;
sbit GLCD_CS1 at LATD2_bit;
sbit GLCD_CS2 at LATD3_bit;
sbit GLCD_RS_Direction  at TRISB0_bit;
sbit GLCD_RW_Direction  at TRISD6_bit;
sbit GLCD_EN_Direction  at TRISB2_bit;
sbit GLCD_RST_Direction at TRISD5_bit;
sbit GLCD_CS1_Direction at TRISD2_bit;
sbit GLCD_CS2_Direction at TRISD3_bit;
char GLCD_DataPort at PORTC;
//const unsigned short Arial20x33[];
char text[6];
unsigned int adc_value;
const unsigned short Arial20x33[] = {
   0x00,
   0x00,
   0x2E,
   0x00,
   0x3B,
   0x00,
   0x21,
   0x00,
   0x07,0x40,0x00,0x00,
   0x0A,0x61,0x00,0x00,
   0x13,0xA3,0x00,0x00,
   0x0F,0x06,0x01,0x00,
   0x13,0x48,0x01,0x00,
   0x13,0xAB,0x01,0x00,
   0x14,0x0E,0x02,0x00,
   0x14,0x71,0x02,0x00,
   0x13,0xD4,0x02,0x00,
   0x13,0x37,0x03,0x00,
   0x13,0x9A,0x03,0x00,
   0x13,0xFD,0x03,0x00,
   0x09,0x60,0x04,0x00,
   0x09,0xA2,0x04,0x00,
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x7C,0x7C,0x7C,0x7C,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 46
   0xC0,0x03,0xC0,0x03,0xE0,0x01,0xE0,0x01,0xE0,0x01,0xE0,0x01,0xF0,0x01,0xF0,0x00,0xF0,0x00,0xF0,0x00,0xF0,0x00,0x78,0x00,0x78,0x00,0x78,0x00,0x78,0x00,0x7C,0x00,0x3C,0x00,0x3C,0x00,0x3C,0x00,0x3C,0x00,0x1E,0x00,0x1E,0x00,0x1E,0x00,0x1E,0x00,0x1F,0x00,0x0F,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 47
   0x80,0x1F,0x00,0xE0,0x7F,0x00,0xF0,0xFF,0x00,0xF8,0xFF,0x01,0xF8,0xF0,0x01,0x7C,0xE0,0x03,0x7C,0xE0,0x03,0x3C,0xC0,0x03,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3C,0xC0,0x03,0x7C,0xE0,0x03,0x7C,0xE0,0x03,0xF8,0xF0,0x01,0xF8,0xFF,0x01,0xF0,0xFF,0x00,0xE0,0x7F,0x00,0x80,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 48
   0x00,0x78,0x00,0x7C,0x00,0x7E,0x00,0x7F,0x80,0x7F,0xC0,0x7F,0xF0,0x7F,0xF8,0x7F,0xF8,0x7D,0x78,0x7C,0x18,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 49
   0x80,0x3F,0x00,0xE0,0xFF,0x00,0xF0,0xFF,0x01,0xF8,0xFF,0x03,0xF8,0xE1,0x03,0xFC,0xC0,0x07,0x7C,0xC0,0x07,0x7C,0xC0,0x07,0x00,0xC0,0x07,0x00,0xC0,0x07,0x00,0xE0,0x03,0x00,0xF0,0x03,0x00,0xF8,0x01,0x00,0xFC,0x01,0x00,0xFE,0x00,0x00,0x7F,0x00,0x80,0x3F,0x00,0xC0,0x1F,0x00,0xE0,0x0F,0x00,0xF0,0x03,0x00,0xF0,0x01,0x00,0xF8,0x01,0x00,0xFC,0xFF,0x07,0xFC,0xFF,0x07,0xFC,0xFF,0x07,0xFE,0xFF,0x07,0xFE,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 50
   0x80,0x1F,0x00,0xE0,0x7F,0x00,0xF0,0xFF,0x00,0xF8,0xFF,0x01,0xF8,0xF0,0x03,0x7C,0xE0,0x03,0x78,0xE0,0x03,0x00,0xE0,0x03,0x00,0xF0,0x03,0x00,0xF8,0x01,0x00,0xFE,0x00,0x00,0x7F,0x00,0x00,0xFF,0x00,0x00,0xFF,0x01,0x00,0xF0,0x03,0x00,0xE0,0x03,0x00,0xC0,0x07,0x00,0xC0,0x07,0x00,0xC0,0x07,0x3C,0xC0,0x07,0x3E,0xC0,0x07,0x7E,0xE0,0x03,0xFC,0xF0,0x03,0xFC,0xFF,0x01,0xF8,0xFF,0x00,0xE0,0x7F,0x00,0x80,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 51
   0x00,0xF0,0x01,0x00,0xF0,0x01,0x00,0xF8,0x01,0x00,0xFC,0x01,0x00,0xFC,0x01,0x00,0xFE,0x01,0x00,0xFF,0x01,0x00,0xFF,0x01,0x80,0xFF,0x01,0x80,0xF7,0x01,0xC0,0xF3,0x01,0xE0,0xF3,0x01,0xE0,0xF1,0x01,0xF0,0xF1,0x01,0xF8,0xF0,0x01,0x78,0xF0,0x01,0x7C,0xF0,0x01,0x3E,0xF0,0x01,0xFE,0xFF,0x0F,0xFE,0xFF,0x0F,0xFE,0xFF,0x0F,0xFE,0xFF,0x0F,0x00,0xF0,0x01,0x00,0xF0,0x01,0x00,0xF0,0x01,0x00,0xF0,0x01,0x00,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 52
   0xC0,0xFF,0x07,0xC0,0xFF,0x07,0xE0,0xFF,0x07,0xE0,0xFF,0x07,0xE0,0xFF,0x07,0xE0,0x03,0x00,0xE0,0x03,0x00,0xF0,0x03,0x00,0xF0,0x01,0x00,0xF0,0x7D,0x00,0xF0,0xFF,0x01,0xF0,0xFF,0x03,0xF8,0xFF,0x07,0xF8,0xE1,0x07,0xF0,0xC0,0x0F,0x00,0x80,0x0F,0x00,0x80,0x0F,0x00,0x80,0x0F,0x00,0x80,0x0F,0x78,0x80,0x0F,0x7C,0x80,0x0F,0xFC,0xC0,0x07,0xF8,0xE1,0x07,0xF8,0xFF,0x03,0xF0,0xFF,0x01,0xE0,0xFF,0x00,0x80,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 53
   0x80,0x3F,0x00,0xC0,0x7F,0x00,0xF0,0xFF,0x00,0xF8,0xFF,0x01,0xF8,0xF0,0x01,0x7C,0xE0,0x03,0x3C,0xE0,0x03,0x3C,0x00,0x00,0x3E,0x00,0x00,0x3E,0x3F,0x00,0xFE,0x7F,0x00,0xFE,0xFF,0x01,0xFE,0xFF,0x01,0xFE,0xF0,0x03,0x7E,0xE0,0x03,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3C,0xC0,0x07,0x7C,0xC0,0x07,0x7C,0xE0,0x03,0xF8,0xF0,0x03,0xF8,0xFF,0x01,0xF0,0xFF,0x01,0xE0,0x7F,0x00,0x80,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 54
   0xFE,0xFF,0x07,0xFE,0xFF,0x07,0xFE,0xFF,0x07,0xFE,0xFF,0x07,0xFE,0xFF,0x07,0x00,0xE0,0x03,0x00,0xF0,0x01,0x00,0xF8,0x00,0x00,0xF8,0x00,0x00,0x7C,0x00,0x00,0x3C,0x00,0x00,0x3E,0x00,0x00,0x1E,0x00,0x00,0x1F,0x00,0x00,0x1F,0x00,0x80,0x0F,0x00,0x80,0x0F,0x00,0x80,0x0F,0x00,0xC0,0x07,0x00,0xC0,0x07,0x00,0xC0,0x07,0x00,0xC0,0x07,0x00,0xE0,0x03,0x00,0xE0,0x03,0x00,0xE0,0x03,0x00,0xE0,0x03,0x00,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 55
   0xC0,0x1F,0x00,0xE0,0x7F,0x00,0xF8,0xFF,0x01,0xF8,0xFF,0x01,0xFC,0xF0,0x03,0x7C,0xE0,0x03,0x7C,0xE0,0x03,0x7C,0xE0,0x03,0x7C,0xE0,0x03,0xF8,0xF0,0x01,0xF8,0xFF,0x00,0xE0,0x7F,0x00,0xF0,0xFF,0x00,0xF8,0xFF,0x01,0xFC,0xF0,0x03,0x7C,0xE0,0x03,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x7E,0xE0,0x07,0xFC,0xF0,0x03,0xFC,0xFF,0x03,0xF8,0xFF,0x01,0xE0,0xFF,0x00,0x80,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 56
   0x80,0x1F,0x00,0xE0,0x7F,0x00,0xF8,0xFF,0x00,0xF8,0xFF,0x01,0xFC,0xF0,0x01,0x7C,0xE0,0x03,0x3E,0xE0,0x03,0x3E,0xC0,0x03,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x3E,0xC0,0x07,0x7C,0xE0,0x07,0xFC,0xF0,0x07,0xF8,0xFF,0x07,0xF8,0xFF,0x07,0xE0,0xFF,0x07,0xC0,0xCF,0x07,0x00,0xC0,0x07,0x00,0xC0,0x03,0x7C,0xC0,0x03,0x7C,0xE0,0x03,0xF8,0xF0,0x01,0xF8,0xFF,0x01,0xF0,0xFF,0x00,0xE0,0x3F,0x00,0xC0,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 57
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 58
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xC0,0x01,0xC0,0x01,0xC0,0x01,0xE0,0x00,0x70,0x00,0x20,0x00 // Code for char num 59
void main() {
   ADCON1 = 0x07;
   TRISA  = 0xFF;
   Glcd_Init();
   Glcd_fill(0x00);
   while(1) {
      Glcd_fill(0x00);
      adc_value = (ADC_Read(0) * 5000ul) >> 10;
      WordToStr(adc_value, text);
      // Draw text
      Glcd_Set_Font_Adv(&Arial20x33, 1, _GLCD_HORIZONTAL);
      Glcd_Write_Text_Adv(text, 15, 20);
      Delay_ms(1000);
      // Erase text
    //  Glcd_Set_Font_Adv(&Arial20x33, 0, _GLCD_HORIZONTAL);
      //Glcd_Write_Text_Adv(text, 15, 26);
