Plecto
Full Member level 5
Hi. I've tried making an LM1875 amp in the past. The last time I had the rectifying diodes and decoupling caps on the same board as the amps and I even put on of the diodes across an input trace (kind of asking for humming). This time around I had the rectifier and decoupling caps on a separate board with a space of around 10cm between them. This helped a lot, but I later figured that a gain of 21 was not enough. Playing at full volume with my android as a source was no where near any form of distortion. I then tried a gain of 28 and finally 40. I still haven't made the amp clip though, but I'm afraid to play too loud because of my small heatsinks (I've ordered a much bigger one). The humming increased as the gain increased and I feel that it is unacceptable.
Both the LM1875's and rectifier boards are homemade PCB's. The spacings and signal traces are 28 mils, output and power traces are 40 mils. I have a ground plane that covers most of the board, but I haven't payed any other attention to grounding than that. What can I do to fix this humming and what causes it? I can see that having a power AC wire close to a signal wire can cause humming, but these wires are no where near each other in my design. Is it really the puny ripple voltage from the decoupling caps that causes it?
Here are some pictures (they are too large to post directly I believe):
http://i50.tinypic.com/27y8jee.jpg
http://i46.tinypic.com/2rfwvwy.jpg
http://i49.tinypic.com/20hkqkm.jpg
http://i45.tinypic.com/2rf3uqw.jpg
