Silikon
jkeys
I have a problem with jkeys (error erasing flash when trying to erase)!
The flash is M28W160ECT I've checked the pinouts and I think that the flash is write enabled! I even tried grounding pin 115 on the STI5518 for BSOD but same result.
Strange to me is that I can read from the flash but cannot write to it
with the new dump form another working receiver.
Another strange thing is that I can read out the segment example 7FE00000 to 7FF00000 and write it back without problems but if I slightly change the downloaded file I cannont write it back to flash.
Perhaps am I'm using false jkeys.def???
I'm using theese ones
IRD, 42, "skymaster", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
IRDFlash, 42, "M28W160CT", 0x88CE , 0x7Fe00000, 0x200000, 2, 2, 0
Please help me setup the new jkeys.def!
the information about the flash can be found here:
https://www.st.com/stonline/books/pdf/docs/10629.pdf
