jkeys definiton for M28W160ECT ???
Silikon
jkeys
I have a problem with jkeys (error erasing flash when trying to erase)!
The flash is M28W160ECT I've checked the pinouts and I think that the flash is write enabled! I even tried grounding pin 115 on the STI5518 for BSOD but same result.
Strange to me is that I can read from the flash but cannot write to it
with the new dump form another working receiver.
Another strange thing is that I can read out the segment example 7FE00000 to 7FF00000 and write it back without problems but if I slightly change the downloaded file I cannont write it back to flash.
Perhaps am I'm using false jkeys.def???
I'm using theese ones
IRD, 42, "skymaster", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
IRDFlash, 42, "M28W160CT", 0x88CE , 0x7Fe00000, 0x200000, 2, 2, 0
Please help me setup the new jkeys.def!
the information about the flash can be found here:
https://www.st.com/stonline/books/pdf/docs/10629.pdf
jkeys unlock version
hello m8
maybe its hardware protected
IRD, 47, "next5000", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
IRDFlash, 47, "M28W160CT", 0x88CE , 0x7Fe00000, 0x200000, 2, 2, 0
Flash, 33, "M28W160CT", 0x88CE, 0x200000, 1, 1, 0, 2, 39, 0
Sector, 33, 31, 0x00000, 0x10000
Sector, 33, 8, 0x1F0000, 0x2000
this isworking of for nextwave 5000 give it a try
wall.exe jkeys
Thanks but it doesn't work with this settings,maybe there is a slight difference because this setting is for M28W160CT and I have M28W160(E)CT.
I've checked the flash status pin and it is not write protected. I can flash via rs232 and the default bootloader program but cannot flash it with jkeys via JTAG.
m28w160ect
C'est simple pour erraser M28W160ECT tu tape sur "devlopement panel"
tu va sur user function "adresse" tu mais 80000000
et tu clic sur "load to" sur fichier que je te donne unloc et puis tu clic "trigger user"
il faut voir que les case ende sous sois des 00000 tu ferme la fenetre et tu choisie le "next 5000"clic sur "flash programing" tu erasse normalement
jkeys wall2.0
Could you please repeat that in english?
Kind regards
m28w160ct m28w160ect
here i give you the lasted jkeys definition
exuse me for this error
m28w160ct m28w160ect diff
The above file isn't a jkey definition file.
please edit your post.
regards
sda
6 pin jkey skymaster
Is there any unlock file to erase an 29LV160DT flash?
THIER
PS: réponse en français si c'est plus facile pour toi
29lv160dt pdf
Try using the wall program before using the jkeys!
find in google wall 2.0 (wall.exe)
unlock m28w160ct
I got it, but it did not work!
I have an unlock file which is here attached but this is for an M28W160ECT flash, what I need is the same for the 29LV160DT flash.
Thanks for your assistance
jkeys wall 2.0 program
With wall it is only possible to write/read at 1FC00000 or 1FE00000 but I need to read/write at 7FF00000.
Someone can help?
unlock 28w jkeys
hello,
I need unlock bin for M58LW032d flash please..
wbr,
to unlock m28w160ct
i need the same for 29LV160DT unlock bin, have you got it? thanks
