is this design synchronous or asynchronous
ajeshar
Newbie level 2
I have 2 Clocks - clkA and clkB in a design
ClkA(200Mhz) is derived from ClkB(400MHz) and both clocks drive different set of flip-flops.
Doubt - is this design synchronous or asynchronous
- how many clock domains are there in this design - 2 or 1.
FvM
Super Moderator
Staff member
Bochum, Germany
There are of course two clock domains. Because they are related, timing analysis is able to check setup- and hold times for domain crossing signals and either try to adjust the timing to achieve timing closure or report violations. Signals directed from the 400 MHz to the 200 MHz domain will most likely suffer from timing violations because they arrive together with the clock edge, supposed "derived clock" means a simple divider.
INS-ANI
Full Member level 3
since both clocks are responsible for independent set of flops, there's two clock domain where each flop's operation is dependent only on domain clock.Hence it should be synchronous.
Please correct me if i am wrong :)
lty
Junior Member level 3
two clock domains
dftrtl
Banned
Bangalore
Design having FLOPS is synchronous design.
you question should be whether these clocks are synchronous or not.They are synchronous to each other.
