Is there anybody know what is Cgs_M?
Alex Liao
Member level 4
Member level 4
It is Parasitic capacitances of the metal routing to source & drain.
What does this mean? The cap between metal and source/ drain?
Does it contribute to Cgs.(gate to source capacitance)?
Depending on modeling philosophy (and particularly
important to things like RF switches and CMOS PA
antenna-matching) the metallization - gate poly
fringing capacitance may be separately, specially
treated (de-lumped from the gate-source, gate-
drain silicon-thinOx-gatePoly plate and fringe) in
the layout parasitic extraction and the SPICE /
Spectre model. This has to be kind of high-level-
architected to ensure that metal parasitics are not
"double billed" (whatever is within the device extent
as-recognized, vs what is outside, needs to be kept
consistent between modeling and post-extraction).
Hi dick_freebird,
So based on you explanation is Cgs_M being considered in the modeling part or in the extraction part if it reflects parasitic capacitance between the gate-poly and source/ drain? To avoid being "double billed", it only has to be presented in one place.
Alex
