tayyab786
Junior Member level 3
following code not give desired ouput
the desired output is random number having length 510,
instead of given random number it will give following pattern
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 parameter length = 8 ; parameter [1:length-4] initial_state = 4'b1101; //for lFSR parameter [1:length-4] Tap_coefficient = 4'b1001; //for LFSR output reg [1:510]chan_array = 0 ; reg [1:length-4]Y = initial_state ; integer Cell_ptr; integer Cell_ptr1; for (Cell_ptr1 = 1 ; Cell_ptr1 <= 510 ; Cell_ptr1 = Cell_ptr1+2) // As max available prim chan = 255 begin for (Cell_ptr =2 ; Cell_ptr <= (length-4) ; Cell_ptr = Cell_ptr+1) //LFSR algo begin Y[1] <= Y[length-4]; Y[Cell_ptr]<= Tap_coefficient[(length-4) - Cell_ptr +1] ? Y[Cell_ptr -1]^ Y[(length-4)]: Y[Cell_ptr-1]; end //end inner for loop chan_array[Cell_ptr1] = Y[1]; chan_array[Cell_ptr1+1] = Y[3]; end //end top for loop
