Hawaslsh
Full Member level 3
- Joined
- Mar 13, 2015
- Messages
- 164
- Helped
- 5
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Washington DC, USA
- Activity points
- 3,422
Hello all,
I posted a question about the LTC5552 (datasheet) mixer and the use of a balun about a week ago, but I had a follow up question. I also posted this question to the Analog Device help forum a while back but never got an answer. According to the datasheet, the IF port of the mixer has an IF bandwidth of DC - 6 GHz, and the port is differential. Would it be possible to use the IF port single ended without using a balun? The datasheet has this to say about the IF port and using it single ended.
However, if i wanted to use the mixer as an upconverter, using the IF as an input, could the same approach be taken? If it isn't possible to use the IF port single ended, it seems that no one could ever use the IF port to its fully potential bandwidth of DC- 6 GHz and would always be limited by whatever Balun they can find?
Thanks in advance,
Sami
I couldn't find a balun that has a wide bandwidth that also reaches pretty low in frequency; ideally 10 KHz - 3 GHz in my case. I would presume when using the mixer as a downconverter, using the IF as an output, I could easily terminate one end of the differential output with a resistor and take the output from the other end?IF+, IF– (Pins 2, 3): Differential Terminals for the IF. These pins may be used for a differential IF or connected to an external balun if a single-ended IF port is needed. The IF port can be used from DC up to 6GHz depending on the external balun bandwidth. DC voltages at IF+ and IF– are 0V.
Thanks in advance,
Sami
