Is it possible to synthesize the post-place & route netlist? Any way to do that? Is it secure to send vhdl/verilog timing model to customer for evaluation propose?
ofcourse it is possible and would be a very risky venture. But I think there are some packages out there which scramble the netlist in an undecipherable way, which disables any synthesis attempts and are safe to part with.
search for them on google.
I think it is FPGA flow!
BTW, in ASIC design, the netlist after post P&R with physical tools can be resynthesized ? I have not done this operation before!
I believe that you can send WLF files but even though you still are at risk, so usually you may take a snap shots "JPEG" of your testbench "simulation" results,
I believe there is another way that use some cryptographic technique so that no inverse engineering can be done but I dunno this way, so can any one help "links at least"
