wolf12
Im doing a project which requires a infrared module that will work for a continous 38kHz signal, the problem is its hard to find such IR module and i got only tsop 1538, which reduces its gain when continuous 38 kHz signal recieved. Since i cant find any other IR module Im thinking to send bursts. I only need 1 switch(when it recieves the signal turn on and when it doesnt, turn off). So whats the suitable pic microcontroller for this (for both Rx and Tx sides)? Also, please give me example code for this in assembly language or C. It would be easy for me if you give an example code for 16F84A.
Tsop 1538
http://www.datasheetcatalog.org/datasheets/2300/300987_DS.pdf
Tsop 1538
