IPC CID program- Clarification regarding exams
praveen24
Junior Member level 2
Bangalore
Hi all,
I want to clear IPC CID exam . Now I am searching for the previous year questions related to that.
If you know anything( ideas,links,and etc,.. ) Kindly share for me.
Thanks all.
If you are enrolled in a CID program then you should get the study documentation, within this are all the answers that you need.
Simply read and study it well, when you get to the exam after your training then simply use common sense, the questions were not hard and they were all related to the documents.
Previous years questions will not likely be available.
The only way you are going to fail is if you have absolutely no experience of PCB design, in which case your doing the CID too soon.
