unavezmasysale
Member level 2
I need to sense the output current of an inverter and I will use a shunt resistor to ground at the end of this. The input of the inverter is 400Vdc and the max current is 1A with a frequency of 30Hz and a duty cycle of 50%.
The signal waveform will be like this:
over the shunt resistor. The peak voltage is 400V and Vrms is 200V.
I need to sense it with the ADC of a DSP of 3.3Vcc.
Can you help me to design a good circuit to the ADC considering that the tension should be focused on 3.3V/2 = 1.65V (Differential amplifier?) and the dissipated power over the shunt resistor must be low?
In my country I can buy resistor of metal film (1% from 10ohm or 2% from 0.22ohm)
Thanks you very much.
