walters
Advanced Member level 2
why it is necessary to invert channel b
What can i use the "invert mode" on the oscillscope for?
My channel B or channel#2 has a invert mode but i don't know what to use it for
example :
1.) If i have a 5 volts peak to peak AC waveform on Channel#1 and a 5 volt peak to peak AC waveform on Channel#2 invert mode = Cancel out to zero volts right?
2.) If i have a 5 volt peak to peak AC waveform on channel#1 and a 2 volt peak to peak AC waveform on Channel#2 invert mode= negative -3 volts
But why would i want to do this?
What does using the INVERT mode or ADD MODE tell a electronic designer or technician ?
I know if you use a the invert mode on channel#2 with the ADD mode is "substracts" channel#1 waveform with channel#2 waveform
Subtration mode= invert mode+ add mode at the same time
When would i use this "subtraction mode" on the oscilloscope? any examples please?
When would i use the ADD mode on the oscilloscope ? any examples please?
When would i use the invert mode on the oscilloscope? any examples please?
example :
