[PIC] interview questions for 2 years in embedded engineer
ahshiq
what are the interview questions would be asked for two years in embedded engineer. i have experience in PIC 16f887. i have done only small projects. i have done manual testing. tool is HI-Tech compiler & MP lab
for 2 years basically will be from the projects you were worked and from that they will start asking the basics of embedded. Then they will ask to write some code by giving some task.
For a technical question on C I always like the one about the various meanings of the 'static' keyword, so many, many followup questions you can ask.
Also, 'Volatile', 'Const' and the meaning of 'volatile const' (It has one which is actually useful in embedded systems code)...
Linker script questions can really drill down into how well somebody understands both the platform and the toolchain.
I like to throw in some questions on development process, requirements, testing and DFT, version control, also some electronics debugging questions (I have a schematic with all the decoupling caps removed, surprising how few spot the problem).
Regards, Dan.
