Interfacing Xilinx FPGA with PCI bus
cippalippa
Member level 2
Interfacing with PCI bus
Hi;
I'm starting a new project and I need to interface a Xilinx FPGA with PCI bus;
I need also to program the fpga from PCI bus in parallel slave mode from my microprocessor.
May sameone help me to make a choice about an external PCI bridge component for best performance or eventually say me other solutions.
Thanks in advance for all
Re: Interfacing with PCI bus
yes,
but how can I configure my xilinx (xc3s200) directly from the PCI bus?
Actually I use a microprocessor board with ISA bus; I have the xilinx's program bitstream in the HDD and I configure my fpga at the start of the machine in parallel slave mode directly from ISA bus; how can I make the same with PCI?
Oops sorry, I must have dozed off while reading your config requirement. Yes, you'll probably need a PCI bridge chip, for example PLX is popular:
http://www.plxtech.com/
Try downloading the hardware manuals for some of Alpha Data's products to get a general idea of how they do it. They use PLX. These are PMC boards, but PMC is electrically similar to PCI. I've used the ADM-XRC-II board.
I used a XC2C256 Coolrunner cpld and made simple PCI target image for it : Output was jtag connected to jtag pins of the fpga. Or you can use serial or parallel configuration pins, if you like.
hi
Is there any PCI X bridge availabe??
Hi cippalippa,
You may want to consider BDS XPCI PCI IP core we have developed.
BDS XPCI PCI IP core is a Xilinx (TM) LogiCORE (TM) PCI compatible PCI IP core.
We offer this PCI IP core for as little as $100 for non-commercial, non-profit, personal use.
For more information, visit https://www.bracedesignsolutions.com.
Kevin Brace
cippalippa said:
Hi;
