Interfacing Uni-polar ADC to Bi-polar Signal
hynix
Member level 5
Inda
Can any body out there tell me or any schematic how can I interface the Bi-polar signal (+/-1.5v ) signal to my 3.3 v adc working in unidirectional conversion(0-3v) Signal.
Hi
You can use an op-amp to move your input signal around 1.5v.
Or use a level shifting circuit to do it.
Regards
If DC part is necessary , you can use 3 serially connected diodes powered by current source (to make linear shift) connected to amplifier output .
If just AC will be measured , simple RC with level shift will be enough .
The simplest is two identical resistors (values depending on your ADC input requirement) as follows:
signal input ----/\/\/-----+----/\/\/-----VDD (3.3V)
connect at + to ADC input.
With above, yr input range is -3.3V to +3.3V.
If you need the smaller range -1.5V to +1.5V, you need some other level shifting circuit :)
Use a vltaje divisor and a follower with Opamp. Connect your signal to the virtual ground generated in the output of the opamp
Intresting !!!
My signal varies +/-1.7v max from the 0v Reference
I wanted to shift the signal to a fixed level of 1.7v from the 0v reference
so that the signal should oscillate at the dc shift of 1.7v making +/- 3.4v from 0v reference
and then I can give to a unipolar adc (0 to 3.4v full scaled) for the conversion.
please sugest me some more idea or shematic.
