hi
i need to interface BLOCK ram (in spartan3E) with MII ethenet interface . as it seems to me the both ram and eth are operatord on positve clk edge . i obtain the clk from ethernet chip to drive the entire logic. it is obvious as i think data is not ready when MII reading from the data lines.
please show me the way. i really appreciate if the solution in verilog.
Thanks
Re: interfacing two blocks where both transfer data in posed
what do you mean by obtaining the clock. since ethernet is serial and i hope you are storing probably 32 bit data in RAM, are you dividing the clock and giving to the RAM.
