interfacing lm35 using pic18f458
farhan13
Newbie level 5
hi,
i'm doing a project which need me to interface lm35 with pic18f458. i need to display the temperature to the 7 segment display. i'm using 3 of them which will display 2 digits of temperature and 1 decimal point. i really need your help regarding the code (in assembly).
btw, i'm using Vref=5V.
wp100
Advanced Member level 5
Prime Meridian
What have you done so far ..? - have you already done any assembler coding ?
If you can post your code and schematic to date then we can see where you need help.
Any particular reason for using that temp sensor or has it been specified you must use it ?
