c8051f005 is a silabs microcontroller i want the output of the executed program will be displayed in the hyperterminal of the PC using UART and it should be displayed in the lcd
---------- Post added at 05:01 ---------- Previous post was at 05:00 ----------
yes i want serial data reception and the same displayed in lcd
Attaching a working experiment on sending data to hyperterminal. A sample program and the details of operation are also discussed. A similar working experiment on LCD display is also available if you need
the program in assembly language is there any pdf for learning c language for microcontroller and is there important procedure to interface lcd with c8051f005
The connections are as shown above, however there is bit of initialization and sending of data that needs understanding the working of the LCD display and the microcontroller.
yeah, there are a lot of books on internet available for learning "embedded C " and yes you have to follow certain rules/protocols for interfacing the lcd with your controller..
i.e. for making the lcd work, you have to give it certain instructions (defined already, read the datasheets or ask someone) but chill off it is easier if you give it a try...
