FreshmanNewbie
Full Member level 5
I just want to know what are the voltage levels on the ethernet differential lines (both single ended voltage level wrto ground & different voltage between the pairs). I havent measured the signal and not able to get the right answer from Internet search
This is the PHY I am using
