peter_england
Full Member level 4
motherboard no display problem all checked like ram , smps and checked monitor also checked post code on pci card it shows the code 55 19 with 3 long beeps pls help me..:sad:
hi kamal please tell me how to check ram vcc and what is means ram spdvcc ref voltage and how to test it ?
thanks kamal
I checked for ram vcc and it's fine I.e 1.8v but I still not tried the Rom programming to refresh the chip actually I don't have the .bin file for the purpose I have the universal programmer but not bin file.
Ok the model is Intel original dg31pr .and also suggest a good programming method I have the pcb5.0 programmer but it's not working well.
Hiiii Kamal i solved this problem also -- i have downloaded the bios .bio file from intel website and flashed that bios using usb pendrive booting into dos and now all problems sloved but please tell me when i reprogram that bios using eeprom programmer using your provided .bin file why problem is not get solved ?? may be the process is not going proper i think whats your opinion ??
Ok thanks but i think the problem is in my procedure with EEPROM Programmer and when i tried that with pendrive method its ok also please tell me where you given that .bin file i am asking only for information .. ..
