installing linux on windows OS
mug.of.gold
Newbie level 2
Can anyone help me loading linux on windows?
really appreciate that..
NK
anafor
Newbie level 5
You may use virtualmachine on your system .
rockstar_212
Junior Member level 1
i think vmware is the best one.
(there are lot of softs like Microsoft virtual PC , Connectix Virtual PC and many more... but i will suggest vmware )
https://www.vmware.com/
calm
Full Member level 4
you can install cygwin on you computer, it is a good unix/linux simulator and free.
eng_ahmed22
Full Member level 4
Salam
I use it, it is perfect,
salam
Ahmed
damunix
I prefer Virtualboxe, very easy to use, opensource, so free :)
raghuchouta
Newbie level 6
Dear Friend,
Ru satisfied with the answers or not? Using all these virtual machines ur system will get slow, unless u have a large RAM for ur system. Better use it as a dual booting system. then it will be ok. otherwise increase ur RAM.
regards,
raghunath chouta
Slayerza
Full Member level 5
South Africa
With regards to the RAM situation, normal windows distributions (Win XP, Vista,..) cannot use more than 2.5-3GB worth of RAM. On the other hand any linux distro will correctly handle all of the available system RAM.
As such I would recommend running windows in linux rather than the other way round.
Cheers
Slayer
maninnet
Member level 5
vmareware is the best, but make sure you the version you use will support the linux you load
GENERALCHAOS13
Newbie level 3
Try ubuntu with dual boot and if u dont lik it uninstall it windows or if u like it uninstall windows in ubuntu h**p://www.ubuntu.com thers links kubuntu edubuntu xubuntu gobuntu
hbk2222
Junior Member level 3
cairo,egypt
try wubi which is a software installed on windows which run ubintu (not virsial machine)
armixic
Member level 1
U.S.A
I am using VMware for half year already. It sure works
AdvaRes
At home
Yes, VMware is a good choise.
But actually I'm facing some difficulties to switch from windows to VMware. Is there a solution to share the files between windows and Linux ?
