Input current of LM3886
uzaifsharif
Newbie level 2
Newbie level 2
Hello, I am new in the field of electronics. I am working on a project that contains an IC LM3886 but I am confused about its input current so, can anyone tell me what input current is required for it.
Thanks
hi
see the absolute maximum ratings
Absolute Maximum Ratings (Notes 6, 5)
If Military/Aerospace specified devices are required, please contact the National Semiconductor Sales Office/
Distributors for availability and specifications.
Supply Voltage |V+|+|V−|
(No Signal) 94V
(Input Signal) 84V
Common Mode Input Voltage (V+ or V−) and
|V+| + |V−| ≤ 80V
Differential Input Voltage (Note
16) 60V
Output Current Internally Limited
Power Dissipation (Note 7) 125W
ESD Susceptibility (Note 8) 3000V
Junction Temperature (Note 9) 150°C
Soldering Information
T Package (10 seconds) 260°C
Storage Temperature −40°C to +150°C
Thermal Resistance
θJC 1°C/W
θJA 43°C/W
Spec may be found below link.
may find figure "Supply Current vs Supply Voltage" / "Supply Current vs Output Voltage" / "Supply Current vs Case Temperature"
max current 60mA
**broken link removed** :
Supply Current Per Channel 50 mA
Actually I am working on an inverter which contains LM3886 amp so plz tell me what current should I supply with voltage of 24V to get suitable output of 60W??? And my second question is that is it necessary to connect heat sink with LM3886???
