Input button test 18F4520
prasad70
Member level 3
Member level 3
Can someone please explain a code testing input button of Pic184520. I used below codes but it didnt work
#define Sw1 LA7
#define Sw2 LA6
TRISA = 0b11111111 ;
while(!Sw1)
Do sth
thks
What compiler you are using?
You code is incomplete. That's why it won't compile and it is not working.
I am sorry for not mentioning compiler. It's HITEC C PRO PIC18.
I just mentioned only the part of the code I used for the project. Code was compiled and worked well except function I used for input button test. What I could notice was that Input button was not detected. Circuit works well with 16F887 MC.
What I want is to get an idea on checking input button.
thks
First, You have to configure the pin as digital input.
Then check the pin in the while loop as LOW or HIGH. Depends on your hardware connection.
If LOW , do something there.
Else not pressed, do some other thing.
Only problem could be, i think you didn't configure the pin as digital input. Try it.
Best wishes :)
I cinfigured port as inputs
CMCON =0b000001 ; // comparator off
ADCON0 = 0b00000001 ;
ADCON1 = 0b00001010 ;
thk
