INL & DNL measurement of 10-Bit DAC
bgpradeep
Junior Member level 2
inl and dnl measurement
Hi All,
I had doubt in the measurement of INL & DNL.
1)
Is 1LSB = Iref/2^N
Here what should be the Iref value as LSB current
source has 20uA and MSB current source delivers
(20uA * 16). Here LSB = 4bits & MSB = 6bits.
Also should N be different or it should be 10
2)
For DNL measurement , it is 1LSB - [ Iout/2^N]. is this correct?
and how is the INL measurement made because
as per the definition it says draw a line joining
the first and last point.
Thanks
sunking
Advanced Member level 3
inl dnl definition dac
Here the Iref is full scale for 1LSB = Iref/2^N
bgpradeep
testing of 10bit dac
Hi All,
For checking the INL & DNL, under what consideration the simulation time is set.
Like for checking INL & DNL, i am giving different codes from 00....0 to 11...1 every time. I did not get for how much time the simulation should be run.
.TRAN 0NS 50NS -> my current simulation time.
Clock is 200MHz.
Thanks
demodb
Member level 4
dnl measurement
the time you need to check all possible bit words is the following. You have 2^10=1024 different values. For a good test to be run you need to run through all levels, each level consists of 10 bits so 10*1024= 10240 bits in total are needed for testing.
Simulating with a clock of 200Mhz gives a sample time of 5ns. This makes the total simulation time 5ns * 10240 = 51.2 µs.
bgpradeep
dac inl dnl measurement
Thanks for the reply.
I wanted to know whether my measurement of DNL is proper.
This is how i am carrying out the measurement:
1 LSB = Iref/2^10 = 19.5uA/2^10 = 19.043nA
For 0000000001, Iout/2^10 = 19.5uA/2^10 = 19.043nA
Therefore, DNL = 19.043nA - 1LSB = 0LSB
For 0000000010, Iout/2^10 = 39.1uA/2^10 = 38.2nA
Then should this be divided by 2 which becomes,19.1nA
Then, DNL = 19.1nA - 19.043nA = 0.057nA/19.043nA = 0.003LSB
For 0000000011, Iout/2^10 = 59.3uA/2^10 = 57.91nA
Dividing by 3 gives, 19.3nA
Then, DNL = 19.3nA - 19.043nA = 0.257nA/19.043nA = 0.0135LSB
and so on.
Am i going in the right way.
Thanks
