Information about Standard Delay Format
rajesh_v
Newbie level 1
Hi all,
Please any one upload SDF related documents . and in which step it is get generated..
Thanks in advance
Rajesh V
SDF ppt
Standard Delay Format ??
Re: SDF ppt
HI
SDF containing original delay values of design.
This SDF can generate thro CELTIC tool (cadence)...
i.e crosstalk analysis tool
Here we give SPEF as input, cdB, then library, routed netlist we get the output as SDF format
We can give this SDF and SPEF to PRIMETIME (synopsys) or ETS (cadence) for timing sign off
Hope this helps
DINESH
SDF ppt
This step comes after routing bcz once u do routing u have to go for R and C values tht is extraction then after extraction u need to go for delay calculation with the help of elmore delay
Remember one thing spef contains resistance and cap values where as SDF contains T=RC tht is delay values
After extracting r and c values the files wil be saved in SPEF format
And after calculating delay it will be in SDF format
Hope this is clear
Bye take care
SDF ppt
Important point
Ur sdf contains both cell delay and net delay
Bye take care
Re: SDF ppt
hi ,
please read this document of Sdf_3.0 version from verilog open international.
Re: SDF ppt
SDF just give the timing info from RC of the net and the cell.
when you use NLDM model, it can work well.
but when you want use CCS model to get the more accurate result,
you should switch to SPEF. exclude you use the SPEF + CCS to generate SDF
Re: SDF ppt
You can find some information in verilog simulator use guide.
Re: SDF ppt
also some training materials in this bbs is available!
