aliraza786
Full Member level 4
- Joined
- Nov 10, 2009
- Messages
- 210
- Helped
- 14
- Reputation
- 28
- Reaction score
- 14
- Trophy points
- 1,298
- Location
- Lahore, Pakistan, Pakistan
- Activity points
- 2,914
i have to design a circuit name 2 channle ir remote controle so i convert the frequency to voltage through LM331 and compre the out put voltage by comparator everything works fine but the problem is when i connect the 555 output pin to lm331 input pin everything works fine but when i transmit the frequnecy through ir led and attach ir reciver at the lm331 frequency input then nothing happpened this means that the problem is with ir reciver..........i use universal ir reciver see the picture attach.......i dnt know the error is due to the frequency response limitation of the transistor or anything else..........
