Induction coil core - which is better?
neazoi
Advanced Member level 6
Greece
Hello I am trying to make a small induction coil from scratch for demonstration purposes.
Which core is better in terms of magnetization, low temperature etc?
1. solid iron core
2. multi-wire iron core
3. Ferrite core from an old radio antenna (loopstick- ferrite antenna)
Any of those will do. If you want to build a large magnet the then iron core is probably better (you don't want to saturate the core, do you?). If you want to show in the lab the AC response of a coil with or without core, chances are you get an even better increase in self-inductance with ferrite.
See this:
https://en.wikipedia.org/wiki/Magnetic_permeability
The bigger the magnetic permeability, the better.
See this:
Thank you very much!
The induction coil produces very high pulsed voltages from a low dc voltage source. So basically the primary is the low voltage and the secondary the very high voltage part. I have seen in flyback TV transformers they use ferrite cores, but I have no idea why.
Would a ferrite core really make an electromagnet, as it is considered a ceramic material?
First point, you didn't really clarify your requirements, thus "Any of those will do" is the appropriate answer.
"Ceramic material" isn't the point, ferromagnetic properties matter.
Inductors and transformers can be calculated in terms of basic electrical quantities, e.g. inductance, windings ratio, series resistance, coupling factor. Did you?
No I did not do any calculations. I am trying to build this induction coil from instructions from an old book. They suggest multiple iron wires tied together to make the core. I was wondering if ferrite or something like this will do better **broken link removed**
What exactily do you want to do in your demonstration? To get a small spark in the secondary winding such as in an automobile spark gap?
Yes, exactly that.
