increasing gain of transconductor
dadaboq
suppose i have a OTA circuit and the configuration is that the two 2stage op amps are connected with a current multiplier with feed back....how can i increase the gain?
I'd suggest to show your schematics.
Av= gm * RL
What's the problem?
Did you consider input impedance on load
Use CMOS unbuffered inverter or FET complementary buffer between stages.
Choose based on Vth and RdsOn. Or simply try a 15V logic gate.
BTW the RdsOn of an old technology CMOS inverter is around 500 ohms and with negative feedback becomes a linear amplifier.
Modern ones are low voltage are 25 ohms in 7 xxxALVC2 ? types. or the type used in MEGA chips.
