Atkin
I have a padframe layout with my basic padframe, pins and a ring for VDD and GND. I am having issues passing LVS.
This is the only LVS issue I have left and all the pads are labeled with pins. I'm hoping to finish up my first run so I can start to refine my layout. Any advice would be much appreciated (hopefully this turns out like my last post where I had an issue, couldn't solve it for hours, then solved it myself within minutes of posting...). I should also specify that the instance is in the layout and that I've tried manually assigning device correspondence in order to try and fix it.
