Register Log in
In differential amplifier, reason of presence of noise at the output terminal
Rahul Sharma
Member level 3
Guwahati, INDIA
Explanation is required. when small signal differential inputs are given to differential amplifier.
(A) When current source is ideal
(B) When current source is practical i.e. have one finite resistance.
If input is given as V1=1sinwt and V2=-1sinwt and Vcm= noise then what will be waveform of VA, VB, Vo1, Vo2 and Vo1-Vo2 in both the cases. I need explanation of each waveform generated.
Ata_sa16
Full Member level 6
Milky Way Galaxy, 179° 56′ 39.4″
In A)
The differential gain is: gm*RL
gm=gm1=gm2=Is/vov
and the common mode gain is (gm*Rl )/2Rs
so your wave forms will be:
A)
common mode gain is zero Rs >> Rl
Va = Vcm+1sinwt /// Vb =Vcm-1sinwt /// Vo1 = -(gm*Rl)*sinwt /// Vo2 = +gm*Rl*sinwt vo1-vo2= -2*gm*Rl*sinwt
B)
Va = Vcm+1sinwt /// Vb =Vcm-1sinwt /// Vo1 = Vcm*(gm*Rl)/2Rs - (gm*Rl)*sinwt /// Vo2 = Vcm*(gm*Rl)/2Rs +(gm*Rl)*sinwt /// vo1-vo2= -2*gm*Rl*sinwt
Rahul Sharma
Member level 3
Guwahati, INDIA
In A)
gm=gm1=gm2=Is/vov
A)
B)
Thank you! Totally agree with you. Even i got the same answers. except according to me common mode gain is = -Rl*gm/(1 + 2gm*Rs) = Rl/2Rs. instead of (gm*Rl )/2Rs (you have written)
Am i correct here??
Toggle Sidebar
