rkwong
Newbie level 2
Hello,
I downloaded various S-Parameter .s3p files of 50 to 200 ohm baluns for 2.4Ghz operation from various vendors (i.e. TDK, Anaren, Johanson) and just want to verify that I get 200 ohm on the differential balanced ports. In looking inside the S-parameter files, they define port 1 as the unbalanced port and ports 2 and 3 as the balanced ports. So when I import it, Microwave Office creates a 3 port device. So in Microwave Office, I just create a simple schematic circuit where I attach a grounded 50 ohm resistor to port 1, and attached the Microwave Office Port elements with Z=100 Ohm to each of the balanced ports of the balun. (for example I use Ports 6 and 7). I then create a Smith chart measurement and measure Port Parameter Z66 and Z77 respectively and define a single frequency of 2.4Ghz. However, I am running into problems. The problem is that if I compare results from different vendors supposedly advertising the same 50 to 200ohm @2.4Ghz specs, I get results that are all over the Smith Chart and are not even close to each other. This also means that I'm not getting the 100 ohm impedance expected at each port (assuming a virtual ground in between, since assuming microwave office ports measurements are with respect to ground, so combining the two should yield 200 ohm). In fact, I get a complex result for the impedance but the imaginary parts are not 180 degrees out of phase as expected, but rather off by maybe 20 to 30 degrees. Can someone advise whether this is the proper way to test the imported balun element or propose an alternative in Microwave Office?
Thanks,
rkwong
Thanks,
rkwong
