I believe you want to create a symbol and a spectre view,
and have the spectre view call out the subcircuit by name.
I haven't done this since before DFII. You may have to
either edit the CDF for pin order, or reorder the pins in the
subcircuit based on how it netlists. Then you will have to
direct it where to find the subcircuit.
If the part is simple then you might find it easier to capture
the netlist into schematic form, this is easy (if tedious) work.
thanks to all!
I solve that problem:
1. cdf -> edit -> create parameter "model" (paramType = string, parse as number = no, parse as CEL = yes)
2. set property cdf -> edit -> simulation Information -> spectre -> Other parameters in "model"
