implement 32bit 33MHz pci-master in ACEX
leonqin
Full Member level 4
Full Member level 4
China
It need -1 or -2 or -3 speedgrade?
and if 66MHz 64Bit?
Hello,
If you want to Implement a master/target PCI core at 66mhz (with a PLDA PCI core), you must choose an altera acex (ie 1k100fc484) with -1 speed grade. In the case of the pci must be operate at 33mhz a -2 speed grade should be ok (do not use a -3 speed grade at 33mhz because it is too slow).
This informations depends also of the pci core selected. :wink:
Base on my experance,-3 is OK for 33M32bit PCI
pci core
Hello,
is it possible to syntesize the al/te/ra vhdl files in I/S/E and implement the core on a x/i/l/i/n/x?
has somebody any experience with it?
thanks,
hqqh
hqqh,
Ask Xinlinx application engineers , they have scripts help you to do the conversion.
