xilinx impact batch parallel cable iv
Hello you can go through the following details and understand the basic of this conf.
iMPACT, a tool featuring batch and GUI operations, allows you to perform two basic functions: Device Configuration and File Generation.
Configuration Mode enables you to configure your PLD designs through four modes of configuration; Boundary-Scan, Slave Serial, SelectMAP, and Desktop Configuration.
File Generation Mode enables you to create the following types of programming files; System ACE CF, System ACE MPM, PROM, SVF, STAPL, and XSVF.
iMPACT also enables you to do the following:
Read back and verify design configuration data
Debug configuration problems
Execute XSVF files
Note You can toggle between Configuration Mode and File Generation Mode using the Mode menu.
Configuration Mode
When configuring devices in iMPACT, you must have one of five cables; Parallel Cable IV, Parallel Cable III, Platform Cable USB, MultiLINX™ Cable, or MultiPRO Cable (Desktop Configuration Cable).
Boundary-Scan
Boundary-Scan mode is an industry standard (IEEE 1149.1, and 1532) serial programming mode. External logic from a cable, microprocessor, or other device is used to drive the JTAG specific pins, Test Data In (TDI), Test Mode Select (TMS), and Test Clock (TCK) and sense device response on Test Data Out (TDO). This mode is the most popular mode of configuration due to its standardization and ability to program FPGAs, PLDs, and PROMs through the same four JTAG pins. The data in this mode is loaded at one bit per TCK.
SelectMAP
SelectMAP mode is supported by the Virtex™ families. SelectMAP mode allows parallel reading and writing through byte-wide ports. An external clock source, microprocessor, download cable or other FPGA is required. The data is loaded one byte per CCLK. This mode is typically used as a configuration mode on devices when configuration speed is an important factor.
Slave Serial
Slave Serial mode allows for daisy-chain configurations and is supported by all Xilinx FPGA families, but not Xilinx® CPLDs. In this mode, an external clock, such as a microprocessor, another FPGA, or download cable are required. Data is loaded at one bit per CCLK.
Desktop Configuration mode is used to complete single, socket-based programming of non-volital devices (CPLDs, PROMs, and System ACE™ MPM ) using the MultiPRO cable and associated sockets. The MultiPRO cable takes advantage of the IEEE-1284 ECP protocol and Xilinx iMPACT software to achieve download speeds similar to the Parallel Cable IV. Desktop Programmer mode replaces the HW-130.
if any further inf is req feel free.
rishi
