ie3d ver 11 probe-feed to patch
Hi balaguru thavamani,
Thank you for your response.
Well, it is actually not a dual-feed,.I am loading the antenna with a capacitor. In order to do that, as it's suggested in the manual, I have to EM simulate the structure with two ports and then in MODUA I should "Add Parameter Module", add one cap on to the feed, short it and resimulate, but I can not even set up a probe feed when working with finite ground plane and a differential Advanced Extension port.
I suspect there is some conflict , that I am not aware of, between those two types of ports (Advanced Extension and Vertical Localized (probe feed)).
May be there is some other way to include vertically positioned lumped element in between two layers in the model where finite ground plane is used?
Thanks again.
