Im trying to model a patch antenna on a finite ground and substrate.I followed the manual in creating the finite substrate.But after the meshing when i try and simulate, it gives me an error message.
"remove current graph from list
remove current graph from list of simulating finite dielectrics"
It is a corrupted message in some older version of IE3D. The correct message should be reminding you on update the license. Please contact support@zeland.com for upgrading your license. Regards.
does the finite substrate option work on the trial version.I got a different kind of error that said "dynamic allocation failed" or sumthing like that.
